Old 03-12-2008, 04:00 PM   #1
insite
this is a classic synchro ring symptom. shift linkage adjustments will do nothing here. in some circumstances, replacing the tranny fluid with some good stuff (i.e. redline) will help.
kurt - since you just had your synchro replaced, drive it easy for awhile. the mating surfaces on the assembly take a little time to break in & form a good fit. drive it easy and take shift slowly from 1st to 2nd. don't just shift as fast as you can. press the clutch and ease the car into 2nd; give the new synchro time to do its job and sync up the next gear.
FYI, the synchros in the 986 / 996 aren't all that quick to react. if you try to shift fast, it will often grind. once the rings wear, they'll grind almost every time.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
