Old 02-22-2005, 06:42 AM   #6
Brucelee
Brucelee's Avatar
The Noah is a fine cover, I have had very good luck with it in an outside setting.
Also, put on Klasse All in One followed by Klasse Sealer. This will handle the fade.
Be very careful when putting the cover on and off. In general, try to put the cover on when the car has been washed and dryed. This will help you avoid swirl marks and other mars to the finish.
The more diligent you are with the Klasse, the less you have to worry but still, puttin the cover on and off needs to be done with care or you sort of cancel out the benefits of the cover.
Certainly, do NOT leave your Box outside uncovered.
Best of luck!
