I also have a child seat installed in my Boxster with the airbag deactivation bracket. My light on the dash always blinks when I start up the engine with the buckle engaged. I wouldn't put my child in the seat unless I see the light blinking.
Take a look under the seat. You should see where the electrical cable harness from the deactivation bracket plugs into a wire harness. Make sure this connection is good and secure. Perhaps it wiggled out. Short of that, take it back to dealer and have them check it out.
Installation of deactivation brackets is considered a warantee item (from what I learned over a year ago on PPBB) so the fix may not cost you anything....
cheers,
-rob
