Old 01-14-2008, 10:32 AM   #2
CJ_Boxster
Send a message via MSN to CJ_Boxster
It wont have a hole for a switch. It'll be clear without holes and you will be able to rotation but its not meant for light orientation, its sorta hard to explain but the entire lense moves. If you clicking to point more backwards, that will make it light all the time... even with the car locked up... if it points straight down it'll be on only when you open doors and unlock the doors.
If you point it to its last setting which is more towards the windshield, it'll be off all the time and not light at all. hope this helps... Order one from Suncoastporsche.com very cheap with these guys.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
