Old 12-17-2007, 10:50 AM   #10
CJ_Boxster
Send a message via MSN to CJ_Boxster
I forget what size the OEM 986 bulb size is. No you dont need the wire harness but if you want some redundancy added to your wiring, the extra harness has fuses incase the balast shorts out, the new harness will blow its fuse to protect your factory wiring.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
