Old 12-14-2007, 05:07 PM   #13
CJ_Boxster
Send a message via MSN to CJ_Boxster
You will have to drill through your black plastic cover on the back of your headlight housing in order to have the wires from the balast pass through into the housing... cause the balast sits outside the housing. Even on Litronics, the balast sits outside the housing and theres a hole in the plastic cover where the wires go through.
If your worried about condensation getting inside the hole you made... Buy some of that black stucky rubber stuff they sell at pep boys or autozone, its used to seal windsheilds onto cars, you can gun up the hole once the wires are in and you should be fine... If you mess up i think the covers are cheap anyway.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
