Thread: Replacing Amp
Old 12-12-2007, 05:57 AM   #11
dcompress
I finished the PNP rear speaker kit and 911 amp swap last night. Thought I would post a few comments.....
The amp was a plug and play swap. You do have to take a razor blacde and shave off two plastic tabs inside the 911 amp plug - they don't line up exactly with the original plug. No big deal.
The PNP speaker kit is great. The instructions were easy to follow. The hardest part is routing the harness up to the front under the passenger side. Small fingers would be a plus here.
If you are going to order the PNP kit and think you might want to swap out your 4 channel amp, make sure you ask for the extra cable to go to the amp so you have it. I didn't get charged any extra for it.
Now on to replacing the front and side speakers with Infinity Kappas.
dcompress is offline   Reply With Quote
