Old 12-03-2007, 08:49 AM   #7
fatmike
I took a good drive today on my winter tires (Dunlops on 17" wheels). Steering is tight and precise with good feedback. Maybe not quite the same as with the 18" summer rubber, but its still darn good.
My Winter tires have a staggered width (wider in the back) so, maybe that matters?
I would go double check your set-up:
- Are you winter tires warped or damaged?
- Are they balanced?
- Are they "uni-directional" tires? If so, are they mounted in the right place so they turn in the designed direction?
- Are your lug bolts tight?
- Is the tire pressure correct?
Good luck.
SOLD - 2002 Boxster S - PSM, Litronics, De-ambered, Bird Bike Rack, Hardtop, RMS leak...
fatmike is offline   Reply With Quote
