Old 11-29-2007, 12:24 PM   #10
Allen K. Littlefield
Allen K. Littlefield's Avatar
Dremel
Originally Posted by HB.
What tool did you use for the grinding? My brackets are not fitting correctly either, the middle hole is not clearing the small screw.
Used a Dremel with a grinding wheel. Not a whole lot as I posted but enough to get a good fit. Also rounded the sharp edge on the bottom of the plate. I did NOT drill any of the fitting holes larger.
Since installing the braces I have added the M030 Sport sway bars and the handling is dramatically improved. No other changes other than Vertex braces fore & aft and the sway bars. Little or no weight transfer in corners observed from behind the wheel. Ordered them from Sunset in Portland Oregon including bushings for $235.00. Most bang for your upgrade book in my estimate.
AKL
