Old 11-21-2007, 11:49 AM   #2
nola911
I am going to do the same color when my new ebrake comes in. Since I have black, a critical match is not important, but krylon fusion makes a dark gray that is close to seal gray. It is a metallic paint, so it has some depth to it. Check out the color at a local hobby/craft shop (local auto parts stores, lowes, and home depot did not have the dark gray)
I painted the insert on my stock shifter with it because some of the original paint was worn off, I was very pleased and after a few coats of clearcoat, it seems to be very durable.
I hear there is a place online that will match your paint code with spray cans, but you will need to use a good primer for plastics before you apply automotive paint on it.
nola911 is offline   Reply With Quote
