Old 09-11-2007, 02:49 AM   #2
boxster
malta
Originally Posted by BoxsterBob - CA
You can replace the microswitch. It's an inexpensive part and can be done yourself if cleaning the contacts doesn't remedy this, however, the switch rarely fails completely, so the problem is intermittent. Generally cycling through the top up / top down cycle a few times will eliminate the problem, at least temporarily.
I've had the microswitch in the hand brake act up a few times in 5 years, a few spirited up / down cycles brings it back on line. Good luck.
Are you in Malta, NY or the Island of Malta?
I live on the island of malta. its a teeny weenyisland of just 120 square miles!!
boxster is offline   Reply With Quote
