Originally Posted by deliriousga
If I hit the brakes hard, the horn will honk. I tested it by tapping on the horn pad and it only takes a touch to make the horn go off so I think the force of the horn pad pushing when I brake hard is causing the problem.
Anyone else ever had this problem or have any suggestions on how to make the horn pad move out a little so it doesn't go off so easily?
TIA!
id take it apart and see if you can adjust it, or shave a little off. but thats just me.
