clear lights are a MUST.. good job...
try replacing the orange bulbs in the rear lights with clear ones that flash orange or buy a set of silver bulbs from ebay that flash orange it makes it looks even better.
for the front, remove the headlight and use some plyers and twist and pull the orange film out then stick some clear bulbs in..
it looks stunning, as remember on a sunny day the orange is visable and looks the same. if you remove the orange film you will have a stunning boxster, with your boxster color white, it will look better than mine... mine is black and clear looks good, just amagine how your white car will look if you remove the film...
check my pic out
