Old 03-07-2017, 05:29 AM   #1
truegearhead's Avatar
Underdrive pulley interference
I tried to install an under drive pulley on my 97 2.5 and found that part of the casting was in the way. Looks like a protruding nipple near the pulley that the factory pulley fits over. Potentially housing a hall sensor to read the holes in the pulley. Can I just grind this down? It's hollow. Anyone run into this?
Edit. Here's what I'm dealing with
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
Old 03-07-2017, 06:50 AM   #2
Project Addicted
jcslocum's Avatar
That will need to be ground down a bit. It's the TDC holder hole/boss. Grind as little as possible!!
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Old 03-07-2017, 07:03 AM   #3
Yes, common issue. Just grind it down the minimal amount so it clears the pulley.
This boss is used to hold the crank at TDC during engine work so you (or the next owner) might actually need it someday in the future.
I used a simple hand file and the aluminum is fairly soft so it didn't take too long (but the access can be a bit awkward).
Old 03-07-2017, 07:07 AM   #4
Great, thanks guys. Shocked I didn't see it in the write ups.
2003 911 C2
Old 03-10-2017, 10:54 AM   #5
Whew these underdrive pulleys really make a difference. What a nice little upgrade
2003 911 C2
Old 03-10-2017, 11:22 AM   #6
Looks like the crank seal needs replacement too.
2001 Boxster S (SOLD)
1989 240sx (Track car)
Old 03-10-2017, 02:07 PM   #7
steved0x's Avatar
It does! I like mine. Cutting down that boss was the worst part too
