Old 01-30-2017, 03:52 PM   #1
2000 Porsche Boxster Battery which one to buy?
EverStart Maxx Lead Acid Automotive Battery, Group Size H7
https://www.walmart.com/ip/EverStart-Maxx-Group-Size-H7-Automotive-Battery/20531542
Duralast Gold Battery H6-DLG
Duralast Gold Battery H6-DLG - Read 5 Reviews on Duralast Gold #H6-DLG
zealous is offline   Reply With Quote
Old 01-31-2017, 10:15 AM   #2
Most lead-acid 12v batteries are made by Johnson Controls or Deka IIRC. Not much difference in the battery performance.Only difference is the branding.
http://www.consumerreports.org/cro/news/2013/04/beware-the-best-and-worst-replacement-car-batteries-can-be-from-the-same-brand/index.htm
Select on correct spec,warranty,price. Lots of anecdotes in Search but it is like oil choice......
If you re in a cold climate a larger CCA # may be an advantage but otherwise minimize the weight with smaller choice from the correct spec range. Get the correct terminal placement !
Old 01-31-2017, 11:41 AM   #3
Thank you!
Old 01-31-2017, 12:58 PM   #4
If you want to spend a few extra bucks go for Interstate
__________________________
'58 356A coupe, just a driver
'00 Boxster S fair weather - daily driver
'11 Jeep Grand Cherokee Limited - winter daily driver
'92 F250 - junk hauler; previous Porsches '95 993;'08 Cayman S;'70 911E
356Guy is offline   Reply With Quote
Old 01-31-2017, 04:02 PM   #5
Just my experience with Walmart Everstart Maxx batteries= Bad
Old 01-31-2017, 06:56 PM   #6
BTW a bad battery can cause a lot of issue!
After putting in the new battery fix everything and runs strong now.
I had a ton of errors coming back and my check engine light on.
Some of the codes were Secondary Air Pump
The car would get stuck in 4th gear and sometime the D would blink and not even show my current gear that I was in.... all of this was caused by my bad battery.
I ended up buying the EverStart Maxx Lead Acid Automotive Battery, Group Size H7
I have to drive 12 hours so will let you know if there are any issues.
I had read somewhere (I think Pelican Parts) Everstart work very well and they are rated one of the best battery's, it fits and has a outlet valve on both side so it was easy to install, just drop and connect.
Old 02-01-2017, 06:52 AM   #7
Multi-Boxer Driver
Deserion's Avatar
Last year I put (another) Walmart battery (an H8, I believe) in mine - replaced the 4-year old Everstart I had in there previously. No real complaints in usage.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
