Most lead-acid 12v batteries are made by Johnson Controls or Deka IIRC. Not much difference in the battery performance.Only difference is the branding.
http://www.consumerreports.org/cro/news/2013/04/beware-the-best-and-worst-replacement-car-batteries-can-be-from-the-same-brand/index.htm
Select on correct spec,warranty,price. Lots of anecdotes in Search but it is like oil choice......
If you re in a cold climate a larger CCA # may be an advantage but otherwise minimize the weight with smaller choice from the correct spec range. Get the correct terminal placement !
