Old 11-27-2013, 10:50 AM   #1
exhaust manifolds, what do I have?
This exhaust manifold is what was on my 99 2.5l when I purchased it. Are these stock? Is there normally a catalytic converter on these?
Old 11-27-2013, 11:32 AM   #2
steved0x's Avatar
The secondary "pre" catalytic converter didn't appear until 2000. That looks like a stock 97-99 manifold.
Steve
Old 11-27-2013, 02:22 PM   #3
aftermarket exhaust manifold
Would the aftermarket header exhaust manifold really make any improvement on power since this doesn't have the pre-cat?
Old 11-27-2013, 02:33 PM   #4
BYprodriver's Avatar
Small improvement at high rpm, probably noticable loss at low rpms.
If I had a 2.5 I would have stock manifolds ceramic coated inside & out to retain heat inside rather than dissipate that heat to the heads & camcover area.
May be able to gain some flow by grinding welds at tube entrances & exit also.
Old 11-27-2013, 04:15 PM   #5
Johnny Danger's Avatar
No matter what you have for headers, those 400-600 cell cats are going to remain very restrictive.
