Old 11-27-2013, 03:33 PM   #4
BYprodriver
BYprodriver's Avatar
Originally Posted by jdlmodelt View Post
Would the aftermarket header exhaust manifold really make any improvement on power since this doesn't have the pre-cat?
Small improvement at high rpm, probably noticable loss at low rpms.
If I had a 2.5 I would have stock manifolds ceramic coated inside & out to retain heat inside rather than dissipate that heat to the heads & camcover area.
May be able to gain some flow by grinding welds at tube entrances & exit also.
