01-12-2008, 08:41 AM
#101
Originally Posted by Franco
Hi, I'd say a cup of coffee
Would that be a tall or grande?
So the stress bar weighs less than a pound (or half kilogram for those outside the US)?
01-12-2008, 09:12 AM
#102
HI, I figured that was going to be your next Question
1997 Porsche Boxster manual
2018 Subaru WRX Sport Tech
2014 Honda CRV
2014 Mercedes Benz 350 ML
01-12-2008, 09:45 PM
#103
I didn't see this mentioned anywhere, so I'll ask. How much does the stress bar weigh? Both Kirk's and Pedro's. Are these things small enough that the weight is insignificant?
If this is a gotta know question I can take them off my car and measure them. I was a bit anxious when the latest iteration came in and installed them right away, so I didn't get a chance to weigh them first.
I did weigh the 2nd iteration bars though and they were really light - less than half a pound each, but those were smaller diameter aluminum bars. The latest iteration that is the subject of the group buy has a steel main bar and larger aluminum side bars, so it's definitely heavier, but still under three pounds. In my book that would count as insignificant.
Kirk
01-13-2008, 08:06 AM
#104
Kirk
Thanks Kirk (and Franco) - insignificant is certainly a fair answer. I was just trying to get a feel for whether there's any weight impact or not.
03-04-2008, 02:08 PM
#105
I finally got mine installed today Too bad it's raining
03-04-2008, 08:13 PM
#106
Is there any data supporting the addition of the side bars? I can see the necessity of the lower stress bar side-to-side (Camber), but there is already significant bracing against fore/aft (Caster) movement.
I've dismantled the rear suspension when I did my tranny work and personally, these side bars appear to be overkill in all but the most extreme track use (I do not incl. Auto-X or DEs).
I have the Mantisport 'Ernie' bar and noticed improvement (not extreme or significant, but definitely improved), + Fr/Rr. Strut Tower braces.
Can someone show me some data that this area requires additional bracing, because I'm not convinced that the side bars are a necessity, or even a positive addition. There's no benefit to over-strengthening something which is already strong enough to do the job.
03-05-2008, 03:48 AM
#107
it is my opinion (as an engineer) that the side bars are not necessary. anti-squat is adequately addressed by the diagonal links. longitudinal flex at that portion of the subframe is tensile and is adequately addressed by the shear plate.
the reason the cross brace (ernie bar) is so helpful is because there are compressive forces between the left and right halves of the subframe that a shear plate cannot resist. because of this, the distance between the lower control arms was actually dynamic under hard cornering loads. the stress bar hard locates the lower control arms (and in turn, camber), picking up where the shear plate leaves off.
03-05-2008, 07:36 AM
#108
@insite - Thanks for the eloquent explanation. You lend credence to, if not confirming outright, my suspicion that these side bars are a redundancy.
Lord knows, I'm not against spending money on improvements. But, I don't wanna do so on things which offer no real benefit.
03-07-2008, 06:48 AM
#109
Well I got my lower stress bar (Bristol Bar) yesterday and installed last night. Installation was a snap with good instructions. The hardest part was chocking the wheels and jacking the car.
I then took her for a quick spin over my local test road. This is a public road so I wasn't really pushing it but I got in enough spirited cornering to feel a difference. Definitely more planted and precise at the rear wheels, especially over uneven road surfaces. Track days are coming soon so I will know more over the next month.
As an added bonus I noticed an absence of creaking noises from the top while slow cornering through rain gutters and up my sloped driveway that normally cause a little chassis twist.
Thanks to insite for discovering this little gem and Kirk for your product development.
03-24-2009, 10:33 AM
#110
I have finally gotten around to installing the lower braces on my car and have a question for those of you who have done this.
I can't get the old bolts out. I understand that they are pressed in and should pop out but I have whacked on them pretty good without any movement and am afraid of breaking or bending something. What is the trick to getting these out?
Thanks.
2000 Black Boxster S
EVO Intake & GIAC Tuning
Headers & Porsche Sport Exhaust System
ROW M030 Suspension
Front & Rear Strut Braces
B&M Short Shift & EVO Billet Linkage
03-24-2009, 11:25 AM
#111
Porscheectomy
Thanks.
I put a nut on the end of the captive stud and hammered away. It gives you a bigger target and keeps the end of the stud from getting deformed. The colder the parts, the more easily it will push out. It feels like it's never going to back out and then all of a sudden it lets go.
