Old 12-16-2016, 05:10 AM   #1
Do you like your Ksports?
Woody
Old 12-16-2016, 08:42 AM   #2
POG champ, 1995.
I haven't messed around with the preload or the clickers.
Previous owner actually has them pretty dialed in.
Not sure how many miles are on them or when they'll need rebuilding.
But yes, so far, excellent.
1999 Boxster 2.5l 5-spd. 168k miles and climbing.
Build: http://986forum.com/forums/show-tell-gallery/63257-greta-not-really-build-so-much-maintenance-record-build-thread-w-bs.html
IG: @ryanjboutin
ryanjboutin is offline   Reply With Quote
Old 12-16-2016, 01:08 PM   #3
POG champ, 1995.
New(er) 3 stalk unit, courtesy of Woody.
Replaced my stalk unit with a gently used unit.
On mine, the blinkers would not stay on unless you held the talk down the entire time you wanted it on.
I have an aftermarket steering wheel on, so getting the factory steering wheel off is up to you. lol
Remove wheel.
Remove clam shell trim pieces.
Remove 24mm steering wheel nut.
Yank that wheel mount off with your man strenfth.
Loosen this brass bolt on the bottom, gently wiggle the unit off.
Gently wiggle off these connectors, DO NOT bend your pins.
There is also a connector on the bottom left side, you will need a really small flathead screwdriver to depress the clip and slide apart.
Connect the wires to the new unit, level your new unit, and tighten (DO NOT overtighten) the brass screw.
Test all of the functions.
Reinstall the clam shell trim pieces, wheel mount, and wheel.
Enjoy.
IG: @ryanjboutin
Old 12-16-2016, 01:10 PM   #4
POG champ, 1995.
You may have noticed some dyked wires.
I have no clue what they went to.
If you know what they are, please tell me.
Going to look at a bunch of drawings to figure it out.
I absolutely fvkcing hate it when people dyke wires. Just disconnect it.
Are you really in that much of a fvkcing hurry?
IG: @ryanjboutin
HTML code is Off
