Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Porsche Cayman Discussions
Old 10-09-2022, 08:55 AM   #1
2005 Boxster, Guards Red,
Juls64's Avatar
Help drivers window
Hey guys quick question. I have a 987.1 and I got home the other day and my drivers side window wouldn’t roll up. I tried the passenger side window switch and that wouldn’t work either. The passenger side door switch works fine to control the passenger window up and down. I took the door panel off and everything is plugged in tight. Am I in need of a new drivers side window motor? Thanks in advance for the help.
"Going that fast, now that's a felony. You'd have gone straight to jail!" :chicken:
Juls64 is offline   Reply With Quote
Old 10-11-2022, 05:48 AM   #2
husker boxster's Avatar
Have you checked fuses? They're located in the little panel by the driver's left footwell. There should be a chart in the removable fuse door panel.
1989 928 S4 5 spd - black
Old 10-16-2022, 04:54 AM   #3
Juls64's Avatar
Hi
Yes I checked fuses, at this point I’m wondering if I need a new window motor ☹️
Old 10-16-2022, 06:37 AM   #4
1998 Boxster Silver/Red
Yesterday... wife says, "The windows in the Edge won't operate unless the driver door is open".
Long story short... I opened the door... and jiggled the wiring loom (?) inside the rubber sleeve connecting from the door to the car. You know... the rubber thing that protects the wires (windows, door locks, everything in the door). I figured after repeated open/closin of the door something may have wonked out a bit.
Sure enough, the gentle wiggling/pushing/pulling of that rubber part housing the wires fixed it.
Just saying. Hope you get it figured out.
1998 Porsche Boxster
HTML code is Off
