Old 04-03-2025, 03:00 AM   #1
Cam position sensors
I have a 2000 Boxster that just had a crank position sensor fail. Code 0336 i believe. Replaced it and runs great.i also replaced the AOS since i was getting smoke occasionally on start up. Since the cam position sensors are probably the originals from 2000, do any of you recommend replacing them as well as a preventative measure? Thanks
1498asr is offline   Reply With Quote
Old 04-03-2025, 05:42 AM   #2
No, replace them when it is needed.
Old 04-03-2025, 01:37 PM   #3
Thank you for your help
