Old 10-20-2024, 06:26 AM   #1
harnishclan's Avatar
Thanks for all the advice! There were so many responses that I didn’t know where to start, but decided to go through the circuit and see what I found.
Turns out that when I adjusted the brake pedal height to level with throttle for heel/toe that it was now too far away from the max extension of the switch to deactivate. Adjusted the height a bit and added a spacer to brake pedal arm, problem solved.
harnishclan is offline   Reply With Quote
Tags
brake abs fault
