Old 12-05-2006, 08:33 AM   #6
Send a message via MSN to CJ_Boxster
Easy, Sorry i didnt reply sooner, The cable that links your interior latch runs along the surface of the sheet metal on the door... just behind the door panel.
If its never been removed, You will notice the cable runs beside another similar cable but it is secured to the door sheet metal by a round plastic clip but the door latch cable isnt. If you pull the clip out, you can fit the door latch cable in with the other similar cable together. Also while your panel is off, take the time to make sure all other things are tightened and secure like the speaker screws and other plastic peices like clips and what not. If you goto PM me and when i get home after 3pm, i will email you a PDF file of how to remove your panel... its really easy if you know where the screws are.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
