Old 11-29-2006, 01:41 PM   #1
Rennzenn
j.fro's Avatar
reprograming rear spoiler
Is there any way to change the activation of the rear spoiler from 75mph to 60 or so?
Old 11-29-2006, 02:10 PM   #2
blkboxster
Guest
Posts: n/a
you only need it at speeds past 75,so theres no point of reprograming it
Old 11-29-2006, 02:38 PM   #3
Ex Esso kid
I know this is kinda dumb but...any Porsche savvy officers of the law are going to think your speeding even sooner, why bother?
Old 11-29-2006, 07:29 PM   #4
If it can be done it'll probably be done with the PST2.
Why not just add a spoiler switch in the dash and operate it manually when you want to do so? $40 and three pieces of wire and you're good to go.
http://www.lawlai.com/sig.jpg
ukchris is offline   Reply With Quote
Old 11-29-2006, 10:34 PM   #5
Hi,
It cannot be done. That part of the software is non-volatile and non-changeable. If you're some Wizard Techno-Geek, it might be possible if you can crack the code, but the PST2 isn't programmed to access that part of the software. It would be a Gargantuan task to say the least...
Happy Motoring!... Jim'99
Old 11-30-2006, 07:28 AM   #6
boggtown
Guest
Posts: n/a
Gargantuan eh? Just hook up a lead to the speedometer "stick" cant think of the name (analog), and set up a lead at the 60 mark and when the 2 touch it will trigger the spoiler. A very low tech, yet effective and automatic solution. Just like a spoiler button but automatic.
Old 11-30-2006, 07:54 AM   #7
Hi,
As you said, very Low Tech, but fairly complex in execution and probably not too robust either.
But, if you're gonna go all Rube Goldberg (Reuben Lucius Goldberg, 1883-1970) on me, why not add a relay to the Spoiler circuit and switch the relay with the output from the OBC Speed Gong? That way, you could program it's deployment for any speed >6MPH...
Old 11-30-2006, 05:37 PM   #8
Rennzenn
j.fro's Avatar
Thanks for all the input. Sounds like I'll either just leave it be or fill the last blank on the dash with a switch.
Old 11-30-2006, 08:46 PM   #9
Hi,
The Dashboard Switch Hack is really quite easy to do. Can be done in well under an hour + you remove one of the Blanks from the Dash. The Switch is PN# 996.613.155.00.A02 - $37.31 from Pelican Parts. You need to make a Wiring Harness too using some insulated Spade Connectors (Radio Shack) and about 2X 4' 18-20ga. wire and 2X 1.5' 18-20ga. wire. If interested, PM me and I'll send you the wiring diagram. Simple setup, you simply plug into the FuseBox where the Kick Panel Switch currently does. Hope this helps...
