Originally Posted by j.fro
Thanks for all the input. Sounds like I'll either just leave it be or fill the last blank on the dash with a switch.
Hi,
The Dashboard Switch Hack is really quite easy to do. Can be done in well under an hour + you remove one of the Blanks from the Dash. The Switch is PN# 996.613.155.00.A02 - $37.31 from Pelican Parts. You need to make a Wiring Harness too using some insulated Spade Connectors (Radio Shack) and about 2X 4' 18-20ga. wire and 2X 1.5' 18-20ga. wire. If interested, PM me and I'll send you the wiring diagram. Simple setup, you simply plug into the FuseBox where the Kick Panel Switch currently does. Hope this helps...
Happy Motoring!... Jim'99
