Old 06-11-2025, 09:18 AM   #7
Originally Posted by maxbottomtime View Post
when the handle is pulled the window drops, but as SOON as i let go the window shoots up. Based on the behavior, I assume the microswitch is in the "stuck up" position. Both doors act this way.
Seems strange that both microswitches would do this at the same time. I think there might be something else going on.
I can try and disassemble to clean the switches (would appreciate help iding them in your photos), but are the switches the same between these and the cheap VW models?
I don't think the microswitches controlling the window have anything to do with what's inside the lock module. FWIW my Bentley manual says the "inside" door lock microswitch is located inside the door panel at the inner door lock release, and the "outside" door lock microswitch is located in the door on the outside door handle.
I can't help you with VW gear compatibility.
