Old 11-24-2006, 01:36 PM   #1
coolant leaked all out
i was at a light and a driver next to me noticed that 'something green' was leaking out of my car.
well all the coolant leaked out, and it was smoking couse it leaked all over the cats or something hot under there.
i topped it off with water and drove it home like this, what can i do now?
i took the carpet out of the trunk and no leaks in the tank...what else can i check?
thx
my cardomain/pictures page
Old 11-24-2006, 01:46 PM   #2
I would get the car up on a jack and at least see what exactly had coolant spilt on it. Look around that area and try to find out what exactly broke/cracked/loosened that would have caused the leak. Good Luck!
Old 11-24-2006, 02:15 PM   #3
I hope you filled it up with distilled water so your coolant system doesn't get clogged.
That really sucks, bro. +1 on the above post. See if you can find if it's something you can fix easily.
I bleed green
Old 11-24-2006, 02:54 PM   #4
i did fill it up with water.
is it weird that it does not leak anymore, anywhere....but after a while the light comes on, the light to the right of the temp gauge, but the actual needle stays at 180 or so....
Old 11-24-2006, 03:54 PM   #5
Regular water will leave deposits though...I'm thinking you didn't put distilled water in it. You better flush the whole system if that's the case. If you are low on fluid the light on the right part of the gauge will flash. If it stays on then the car is telling you it's getting overheated. I wouldn't drive it until you find out whats going on.
Old 11-24-2006, 04:39 PM   #6
07 Carrera S Cab
Boxtaboy's Avatar
You could have the old style coolant cap which Porsche updated, cause the old one released coolant at a lower pressure than desired. Check if you have the old one or not. Also, these guys are correct, if you do add water, make sure it is distilled water, and not plain water or mineral water, or else you'll have to flush the whole system.
Left is old coolant cap, right is new updated one (it's only like $25 bucks at dealer):
Old 11-24-2006, 06:42 PM   #7
Thanks Adam, that's what I was getting at when I said distilled water. I wouldn't want his coolant systems gunked up with mineral deposits.
I bleed green
