Originally Posted by Adam
Regular water will leave deposits though...I'm thinking you didn't put distilled water in it. You better flush the whole system if that's the case. If you are low on fluid the light on the right part of the gauge will flash. If it stays on then the car is telling you it's getting overheated. I wouldn't drive it until you find out whats going on.
Thanks Adam, that's what I was getting at when I said distilled water. I wouldn't want his coolant systems gunked up with mineral deposits.
