Old 08-26-2022, 11:48 AM   #1
jaykay's Avatar
steering wheel column trim
Has anyone been able to remove the top trim cover piece without removal of the steering wheel and.. then replace it
I ask as I dont want to be stuck removing the wheel anyway after having broken 20+ plastic tabs
986 00S
Old 08-29-2022, 05:21 AM   #2
PLP
PLP's Avatar
You can remove the steering wheel without involvement of any clips.
I did it, so can you.
As for the trim removal.
Nope, cannot be done as there are screws in the front, if I recall.
Steering is easy.
Just disconnect the battery.
Current rides: 2003 Porsche Boxster MT (me), 2019 Bolt LT (me), 2015 Audi Q5 (wife), 2008 VW Rabbit (2.5 inline 5, MT, well, for kid... but you now, it is the 5 straight)
Previous: 2014 Fiat 500e, 2016 KIA Forte5 SX, 2016 Fiat 500X, and some old days: Trabant, Fiat 126p...
PLP is offline   Reply With Quote
Old 08-29-2022, 03:41 PM   #3
jaykay's Avatar
Okay,
I was thinking I could get one screw at a time by turning the steering wheel but I am not sure I have the distance to withdraw the front cover clear any clips and be able to pry off the top trim cover didn’t even want to get in there if it’s not possible… Trying to avoid breaking things
986 00S
Old 08-29-2022, 04:29 PM   #4
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by jaykay View Post
Okay,
As PLP said, removing the steering wheel is fairly easy. Things get broken when you try to find short cuts rather than doing it the right way.
This article has a decent guide: https://www.pelicanparts.com/techarticles/Boxster_Tech/91-ELEC-turn_signal_switch_-_OBC_upgrade/91-ELEC-turn_signal_switch_-_OBC_upgrade.htm
Old 08-29-2022, 07:04 PM   #5
jaykay's Avatar
Thanks for the advice. I am time limited on most tasks so I need to be coralled!
986 00S
