Old 08-29-2022, 04:29 PM   #4
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by jaykay View Post
Okay,
I was thinking I could get one screw at a time by turning the steering wheel but I am not sure I have the distance to withdraw the front cover clear any clips and be able to pry off the top trim cover didn’t even want to get in there if it’s not possible… Trying to avoid breaking things
As PLP said, removing the steering wheel is fairly easy. Things get broken when you try to find short cuts rather than doing it the right way.
This article has a decent guide: https://www.pelicanparts.com/techarticles/Boxster_Tech/91-ELEC-turn_signal_switch_-_OBC_upgrade/91-ELEC-turn_signal_switch_-_OBC_upgrade.htm
