Old 04-02-2022, 05:41 AM   #1
DIY adjustable toe link with bump steer
Trying to DIY a adjustable toe link with bump steer. Now all I need to find is a heim joint pin with enough length and...The Porsche-angled taper. The taper part is where I'm stuck.. When I measure the oem pin I find that it's something like 5,5 degree. Not sure I'm accurate enough.
Any ideas?
Old 04-02-2022, 07:26 AM   #2
Measured on the steel insert in the hub and now I get it closer to 4,5 degrees taper.
Anyway, I might found what I'm looking for, RSS has a separate pin made fot the 986. It looks kind of short to handle bump steer but It's supposed to work so..
