Old 07-06-2021, 05:23 AM   #1
elgyqc's Avatar
My home made hub puller
When faced with the unexpected task of changing my rear wheel bearings I ran into the challenge of removing the hubs. The tools most often used seem to be the Grappler, which is too expensive for my budget, or a slide-hammer. The slide-hammer put me off because all that hammering is directly transferred to the suspension.
I found this thread which which inspired me:
https://rennlist.com/forums/996-forum/925423-wheel-hub-removal-tool.html
Looking at this tool I decided I couldn’t just copy it because my welding abilities would not allow the little feet to be strong enough, so I looked at how to support the legs directly on the hub carrier. Unfortunately there are no support points 180 degrees apart that allow the tool (which I call my puller support) to be centered over the hub. Also I wanted to use my standard 3 arm puller rather than a bolt.
After studying the hub carrier and my available materials (lots of 1 ½ inch square tubing) I came up with this.
The short piece of tube bolts in place of the brake caliper (with the caliper bolts).
... and the puller support has one leg on it and the other on the hub carrier extension for the track rod.
The bungee cords hold the support in place while installing the puller.
It worked fine on the first hub.
Grant
Old 07-06-2021, 06:01 PM   #2
Artist, 986S tinkerer
NewArt's Avatar
Simply genius my friend!
Old 01-29-2022, 01:17 PM   #3
elgyqc's Avatar
I was not sure that this would work on the front end... but it does.
Grant
Old 01-31-2022, 05:38 PM   #4
elgyqc's Avatar
Here is a better picture of the front right hub coming off.
Grant
Old 02-05-2022, 05:31 AM   #5
still plays with cars...
BoxsterSteve's Avatar
This is
Absolute genius.
You can count on me copying this when it’s my turn to do wheel bearings.
Six speed 2000 Boxster S
Old 02-05-2022, 07:20 AM   #6
986tate's Avatar
Totally. Could you share dimensions?
I guess it depends on what you’re using as a puller
986tate is offline   Reply With Quote
Old 02-05-2022, 07:15 PM   #7
elgyqc's Avatar
I used 1 1/2" square tubing.
The piece that bolts in place of the caliper is 7 1/2" long with the holes 5 1/8" on centers.
The cross piece is 10 1/2", the longer leg 5 1/4", the shorter one 4 1/2" and the distance between the legs 7".
I had to strengthen the area where the puller bolt contacts the cross piece... the tubing was deforming under the pressure.
I broke my (cheap) 2 arm puller so bought the 3 arm puller which worked fine. I think a better 2 arm puller would work.
Grant
