Old 11-25-2022, 10:17 AM   #15
elgyqc's Avatar
Quite a few probably. Did you find particles from the chain pad in the sump? When that goes the chain starts running on steel producing some metal shavings.
I took a look at the filter this morning, no plastic and the metal is copper coloured and I found lots of copper in the oil pan... so definitely rod or main bearings.
Grant
