Old 09-07-2021, 10:10 AM   #1
If you're talking about the sensor at the front of the engine that's accessed by removing the panel behind the seat, I put my replacement in at snug and it's been fine - no leaks. That was 9 yrs ago.
Have the replacement ready as you'll get a gusher when you remove the old one. Work quickly and you won't lose too much antifreeze.
Thanks Husker, the coolant temp sensor swap went real well and quickly, but from underneath - the car on a lift. Tightened it snug, should not be too tight...
Did change the two front of the engine large diameter coolant hoses at the same time (looked to be at the end of the lifespan, probably original), so coolant flush was also done at the same time
2001 996 C2 Manual
pilot4fn is online now   Reply With Quote
