07-30-2021, 05:43 AM
#21
On the slippery slope
Originally Posted by 1thenaton1
Consider a set of 17 inch wheels, 4 rears if you can swing it, for track use. Tires are a wear item and the 17 inch variety cost significantly less. Bonus of the square set up is you can rotate your tires as you will no doubt be chewing up the outside edges (based on not seeing camber adjustment in your mods list). re71 in 255 40 17 were recently on super sale from tirerack as they are being discontinued and I was glad to pick up a fresh set. I will likely try the Falken 660s next
17's are definitely the way to go for track use.
While square setup may have some advantages, it can also put you in a car class where you are less competitive. Things like tire size do effect what class you run in
2004 996 Targa Tip
Instructor - San Diego region
07-31-2021, 04:15 PM
#22
Well I just got a set of 996 Lt Alloy Carrera wheels for pretty cheap and they're being refinished. I'm going to use them for my track wheels for now. Since I'm not wearing the outer edges of my tires yet, my shop didn't want to try setting my car up with more negative camber. Maybe once I get faster and start wearing tires on they outside edge instead of evenly they said.
Do the 17 x 8.5 rears fit on the front with 255/40 tires if the car still has factory springs rather than coilovers? If they do, I'll keep an eye out for a pair of rear Boxster S II wheels since I already have a set of those.
08-25-2021, 04:23 PM
#23
Update
08-26-2021, 05:17 AM
#24
Nice! They should be beyond amazing on the first lap but fall off pretty hard after that. Let us know how they hold up after 3 days. Watch your shoulder wear as they typically like a lot of camber which you don't appear to have.
08-26-2021, 06:45 AM
#25
+1
Let us know how it goes on the Advans. I'm curious how it performs with the spacers; I recently removed mine for safety as I discovered a wheel shimmy at around 60MPH-70MPH.
2001 Porsche Boxster S
08-26-2021, 10:46 AM
#26
Originally Posted by PaulE
I had the wheels checked for trueness and refinished with metallic silver powder coating.
Paul, your wheels came out pretty nice! I would 'like to suggest' installing the center caps it will make the wheels stand out better..
There is a guy on Rennlist that offers (non OEM..) center cap sets for about $50 bucks and they look pretty good (I got a set for a friend of mine's 997 and they look great IMHO, specially for the cost..
08-26-2021, 06:57 PM
#27
Originally Posted by bcrdukes
+1
The 20mm spacers on the rear put these 996 wheels where they need to be on a 986. I drove 40 miles home yesterday from the shop on the highway and they don't shimmy at all. My preference would have been for a wheel that didn't require a spacer, but these wheels were too good of a deal to pass up!
Yeah, right now I'm on the stock alignment settings for the ROW M030 suspension. I've been on Michelin Pilot Sport 4S tires with no shoulder wear, we'll see how these do. I hope they feel good for more than 1 lap!
Thanks Gilles, I've got center caps, including a set of Fred's (Nine8Six) faux centerlock caps. I've left them off for now as I'm headed to the track!
