02-26-2021, 06:31 AM
#1
Transmission Drain Plug Size (internet seems to be wrong)
I'm trying to replace my drain and fill plugs with AN fittings to for a trans cooler. I looked up the thread size and I can see multiple sites claiming its M18 1.5 but that is too small and the incorrect threads. The fitting on my transmission are tappered threads. Anyone know the correct size?
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
02-26-2021, 06:58 AM
#2
I posted too soon, they're M24 X 1.5. Or at least I think they are. they're tapered though which is a problem, I can't seem to find M24 X 1.5 tappered threads to AN. Surely someone has solved this problem..right?
2003 911 C2
02-26-2021, 06:59 AM
#3
When i had mine out it appeared to be regular 1/2" NPT. I didn't test, so not positive.
02-26-2021, 07:43 AM
#4
Yup: A welder.
02-26-2021, 07:53 AM
#5
There's an aftermarket kit for transmission cooler made by tunermotorsports. Maybe try to contact them to see where they source the fittings?
Sent from my POCOPHONE F1 using Tapatalk
02-26-2021, 09:57 AM
#6
Who's askin'?
I actually just went through this this week. Yes, it is an M24x1.5 tapered thread.
I couldn't find any off- the- shelf fittings that would work without adding too much of a "hang-down". ;-)
I went to my local Bridgestone hose products store, where their genius in the back built me a fitting.
He drilled the plug, and then welded in an NPT fitting. From there, I actually added a Tee, so that I could also plumb a temp Gauge.
02-27-2021, 02:02 AM
#7
Try British American Thermal in Fla. they have many fittings.
https://www.batinc.net/plumbing
02-27-2021, 04:17 AM
#8
If you haven't installed them yet, can you take pics?
02-27-2021, 05:10 AM
#9
Who's askin'?
I'm sorry, i installed it same day. But I'll see if I can snap a pic with it in place. (Unfortunately, I already put the stressed- member plate back on as well)
