Old 10-26-2006, 01:27 PM   #1
Exclamation Alarm Control Unit Disaster!!
Hello – please help!
This week I took my 1999 Boxster (2.5 L) to one of the better Porsche mechanics in Portland, OR. My Alarm Control Unit (located under driver’s seat) had gotten wet and no longer worked properly ($315 diagnostic time at the dealer so didn’t want to go back to them). The problem is the doors don’t lock and alarm doesn’t set. Even under Emergency Mode (3 turns to right with key) one door does not lock. Plus interior lights stay on longer than they should (20+ minutes).
Anyway, I had the new Alarm Unit (996-618-260-07) and gave to the mechanic with the Learn Code numbers. They could not get the car to accept the unit. They then found that the gas door locking servo had failed as well. They suggested that sometimes this malfunction fries one of the drivers in the Alarm Unit and could have created the problem.
So they replaced the gas door locking servo (997-624-113-00) and tried again with no luck. Here is what the report says after they charged me $455 with not even fixing the problem!! They originally said it would be no problem and should cost 140-160. Afterwards they said they have never experienced such trouble with a car. I guess it is haunted.
“Check/clean electrical connections at ECU. Locked new control unit with immobilizer number supplied by customer. Coded version 4=USA. Attempted to teach new control unit, transponder key and remote controls. “TIME BLOCK RUNNING’ shows on PST2 and will not respond to teach functions. Replace servo unit for fuel door. Retried to teach new ECU, remotes and transponder keys. Still shows “TIME BLOCK RUNNING” and will not respond. Reinstall old control unit to make vehicle useable.”
So, how can I get the car to accept the unit and work properly? I am planning on going back to the mechanic with your suggestion so thank you, thank you, thank you to anyone that can help!
iccubed is offline   Reply With Quote
