Old 12-10-2020, 10:18 AM   #7
Originally Posted by alynch View Post
I want to replace the fluid without the hassle of removing the braces and the pan but want to make sure the hole is the right location. 2000 Boxster S.
Alynch, removing the aluminum bracket (and braces) takes you less than ten minutes
Just remove the wheels and use jack stands to ensure that you don't have any weight on the suspension, after removing the triangle you would be able to drill a drain hole properly so next time will be a breeze..
