Old 12-10-2020, 08:21 AM   #5
gonz
I read through all the different posts I could find, got the hole saw out, measured and drilled, and then found out the spot was not right for my 2001 S model. It wasn't off to the side for the drain, but rather directly in the middle of the plate. I had to drill another hole as it was way too far off to drain properly. I'm going to assume the 2001 S and 2000 S are the same but measure if you can. I recall a measurement but I don't want to give you a bad number. I can get under my car this weekend to measure and post it here.
The fill plug wasn't where it was supposed to be (by the axle) as well. It was on the driver's side (US) back by the end of the transmission. I finally found a picture of the location reading through a Pelican sales page. Let me know if you need to measure the drain plug location.
gonz is online now   Reply With Quote
