Old 10-29-2020, 10:11 AM   #1
Problem with vibrations since car was in workshop
Hi,
my 2003 986 was at a workshop. Since than i have problems with vibrations in the drivers footwell. The vibrations appear to come from the footwell floor / side panel and appear also in the gas pedal (which in my car is electronic – so no throttle cable).
The vibrations are engine related. They disaapear immediately if i press the clutch and the rpms drop.
The car was in the workshop to do:
DMF, clutch, pressure plate, release bearing, clutch servo spring
Water pump, thermostate
IMSB
Front engine mount
and some other things
I also asked them top check the 2 other hydro engine mounts. They didn't do that. They've said that they never fail, hm...
They said there are no vibrations or that they cannot feel any unusual vibrations. All of these cars would vibrate, blah blah...
In the end they replaced again:
and put in an old engine front mount in
The IMSB (open roller bearing) wasn't replaced.
The vibrations in the footwell are still there. Additionally i now have vibrations in the drivers seat and centre console.
The vibrations start at aound 2.000 rpm and disappear above around 4.500 rpms. The vibrations appear under light to heavy load. No appearance with no engine load. They are definitely not undercarriage related.
I suspect there is a problem with the engine mounts or that the drive train is tensed in some way. Or that there was something going wrong, when they installed the IMSB.
Has anybody experienced similar vibrations from the engine in the drivers footwell?
Thanks and regards
