Old 09-25-2020, 10:12 AM   #1
986 no start
Hi All
Currently my 2.7 Boxster will not start. The car ran out of petrol and also stood for a couple of months so what petrol was left completely evaporated. I did try starting the car forgetting it had no fuel in it and I must have cooked the petrol pump as it was not working when I took it out. I have put new pump in but the car will not start, it cranks over fine, the fuel pump fuse is good and the relay is a new porsche one I have just installed and yes there is now plenty of fuel in the tank. I have checked for codes with icarsoft por v2 and have none. I am thinking maybe I do not have enough fuel pressure but I have cranked the car a few times now so I must have built up the correct pressure. Can anyone think of any other reason the car cranks but will not start. Cheers Neil.
MondialNeil is offline   Reply With Quote
Old 09-27-2020, 05:38 AM   #2
Originally Posted by MondialNeil View Post
Hi All
I would do a fuel pressure test at the fuel rail to make sure I had fuel pressure at the injectors.
Nominal fuel pressure engine off 3.8 plus or minus 0.2 bar.
Engine idling 3.3 plus or minus 0.2 bar
blue62 is offline   Reply With Quote
