07-20-2020, 08:30 AM
987 Rear Spoiler won’t operate ?
All of a sudden the dash switch won’t raise the rear spoiler, and the LED does not come on.
The only thing I had done to the car was replacement a convertible top (lift arms) Part on each side.
Is the spoiler on a Seperate fuse ? Where should I start to trouble shoot ?
07-20-2020, 02:01 PM
Just repaired the spoiler system on my 01 986. This is a Porsche non repairable assembly priced at about $1300. for my car. I don't know that much about the 987.
Check your owners manual for the location of the fuses for the spoiler motor. Mine were located in the foot well fuse block. They were good. Then check the relays (2) one for extend and one for retract direction. Both are the same, so maybe swap the as part of trouble shooting. Mine are in the trunk. Mine were good. Micro switches located inside the spoiler assembly was the root cause of my failure, but I had a dash light warning of incomplete function not reaching micro switch, It's quite the learning experience repairing the system and I understand why Porsche only offers the entire assembly. If you are mechanically inclined... I would go for it. What do you have to lose? Time or money! You can probably jump the motor to see if it works. You could also have a manual switch deployment failure in the system if your model has one, not to mention instrument cluster failure. Mine deploys automatically at 75 mph and retracts at 50 mph. If you have a manual switch in the door of the foot well fuse block try it. If it works you have a deeper dive than just fuses and relays... Good luck with it and I hope I helped in some way.
07-21-2020, 03:41 PM
Thanks for that. The 986 system was easier to diagnose, the 987 is a little deeper.
I still did too a 75mph drive to test the automatic feature.
Right now, I lost the in-dash with feature.
07-21-2020, 07:04 PM
Sounds to me if the automatic function works...It night be just the switch in your dash.
That would be good if that is all it is. I would change it or jump the switch and see if it functions before buying one.
I hope you sort it out painlessly. I hate it when anything in my car doesn't work as intended.
07-26-2020, 04:59 AM
How hard is it to pull that section of the center console to check the connection ?
09-03-2020, 01:26 PM
After the console rear spoiler switch stopped working the 12v cig lighter power outlet in the passenger well stopped working.
Are these operating on the same circuit ?
Anyone had experience with the wiring to the cig outlet in the passenger well ?I'm thinking its related to that spoiler switch....?
09-25-2020, 04:18 PM
Replaced the Two 13v outlet fuses; no effect on the spoiler switch. is there a test I can do in the trunk ? It's a 2006 987
01-15-2021, 11:38 PM
Hi Jim, any update with the spoiler switch issue. Did you solved it?
I have the same problem in my boxster 07.
The spoiler Led doesnt turn on and the spoiler is inop.
I Check my fuses and the only one broken was the cigarette one.
Thank you.
01-16-2021, 05:14 AM
1998 Boxster Silver/Red
Pull the spoiler switch and jump it. That should reveal if it's a simple switch replacement. God luck!
1998 Porsche Boxster
04-04-2022, 05:59 PM
Update
Ok; finally took the 987 to my Indy for a PWIS test. He could operate the spoiler with the pwis.
Next question is how can I test that switch ? And what would that switch cost ?
And, how is that switch removed for testing ?
@Rod86
Reason: Update
04-05-2022, 05:48 AM
You'll need to check the switch with an ohm meter. There would be tutorials on YT.
To get to the wires (and to replace the switch), you'll need to tear the center console and shifter area apart to get to this section of the console. Be careful - there are lots of delicate arms that snap into place. Break one and that particular piece may be rendered useless. A set of trim remover tools comes in handy. There's prob an article on Pelican Parts about how to remove the pieces of your console or there may be a YT vid. Many parts will have to be removed before you can get to that section. Once you have that section out, you can check the switch with the ohm meter and replace it if necessary. It just snaps in / out.
A bit of google searching will find the part # of that switch (assuming you need to replace it). Check with the dealer for a price, but chances are it will be cheaper to buy that section of the console (with the switches already in place) on ebay.
Top Tip: when working on tearing interior panels out, I go to ebay to find those particular panels. Sellers will show back side pics that will display the locations of the snaps and screw heads. Comes in handy to know where they're at when attacking blind from the front side.
1989 928 S4 5 spd - black
04-05-2022, 09:20 AM
Thank you for the explanation; That helped a lot !
04-16-2022, 04:49 PM
Went ahead and bought anew switch Module fromSunset Porsche in Oregon.
FYI: Part No: 997-613-133-00-FMH and its called a Porsche Stab Switch
Reason: Add pic
