Old 06-21-2020, 03:11 PM   #6
Originally Posted by Newsguy View Post
Yes.
Oil followed after two gallons of coolant.
Well if you didn't pour coolant into the oil filler tube. Then two gallons of coolant in the sump is sorry to say a major issue.
If you have access to a coolant system pressure tester you may be able to put pressure to the system and then hear air passing buy listening at the oil filler tube and around different point of the engine.
you can remove the plugs and listen with a piece of hose at the plug holes. Sorry I can't be more help
