Thread: Oil & Water
Old 06-21-2020, 09:31 AM   #3
tonythetiger
Will there be cake?
tonythetiger's Avatar
Need more information, yeah? What testing did you do in the new engine. Compression and leak down should have happened before an investment of labor. Were you replacing fluids before running it? The oil cooler leaking would be bad orings or improper installation, but wouldn’t intermix with running the car. A pressure test on Coolant system should reveal defect also. Its a closed system, so some simple tests should point to problem.
