Old 04-30-2020, 02:54 PM   #1
Will there be cake?
tonythetiger's Avatar
986 S exhaust troubles
I am at wit's end...several days in, many hours invested trying to remove the center pipe from the flange of the exhaust manifolds. One bolt on the top is welded in, nothing on the other side...corroded away, one nut and the protruding stud on the bottom is snapped of and one nut came free.. I can't get the flange free. cant get the studs to budge.
penetrating oil and torch have proved ineffective.
anyone have any advice? I am scared to attempt removing the manifolds, although the bolts look pretty good, surface rust and such.
Look at this debacle.
If I go for the manifold bolts, how do they look and what should I do to insure I dont snap those off?
should I consider cutting off the flange on the rear side and replacing the back cat pipes?
something gotta give.
