Old 05-01-2020, 03:49 AM   #5
rfuerst911sc
Pulling the manifolds I would be careful applying too much heat , instead I would take a long punch and hit them in the center of the bolt head . You are just trying to shock them enough to make it easier to break them loose . As you know breaking these bolts in the head will make your life more miserable . Spraying some PB Blaster on the bolt heads and tapping them with a punch/hammer may get enough penetrant in there to help . Good luck I feel for you . And of course when you do get it apart apply anti-seize to all fasteners .
rfuerst911sc is online now   Reply With Quote
