Old 04-09-2020, 12:17 AM   #1
Rear heat shield needed?
Allways looking for possibilities to reduce weight. Those heat shields on my picture, are the really needed? Seems to be protecting the rear bumper cover from heat. I figure that I might keep the shield above the exhaust but remove the one behind and on the sides. Using a modded "che-catback exhaust" fyi.
Any thoughts? Will the bumper cover be damaged without the shield?
Robert986 is offline   Reply With Quote
Old 04-09-2020, 06:07 AM   #2
I've removed all of the rear heat shielding and rear bumper brace from mine. Every race car I've seen has had them removed too. Most race cars have a hole cut in the rear to let heat out though. I'm thinking you'll be fine even if you don't cut a hole in your bumper because of where you live.
Woody
Old 04-09-2020, 07:09 AM   #3
BYprodriver's Avatar
They don't weigh enough to matter removing them.
Old 04-09-2020, 07:09 AM   #4
Thanks!
Even though it can actually get pretty hot even in Sweden, I guess it should work. I guess the risk is daamaged paintwork if it gets too hot..
Old 04-09-2020, 07:14 AM   #5
No weigth is too small in my World.. But I see your Point. What I donīt want though is a hackjob that will make the car look butchered or interfere too much with functionality.
Old 04-09-2020, 10:48 AM   #6
A little bit here, a little bit there, it all adds up. I removed 250lbs from my boxster removing unnecessary items
Woody
Old 04-09-2020, 01:01 PM   #7
Exactly.. I only left one of the horns btw
Old 04-13-2020, 03:56 PM   #8
Yes, just remove it. Unless you sit in traffic it shouldn't be an issue.
After I removed all of the rear heat shield, I ran some adhesive "gold" insulation under the trunk area. It eventually it started to fall off, so I removed it. Doesn't look like a necessary item and the DME still works.
If it doesn't serve a purpose remove it
PCA Intermountain Region Track Chair
SPB #50
MaxD is offline   Reply With Quote
