Old 03-28-2020, 03:59 PM   #2
Originally Posted by flmont View Post
So as I was changing out the oil fill tube that bolts to the engine A piece of the plastic lip chipped off,..Iam sure its now in the engine with no way to retrieve it,is it possible it could work its way straight to the sump..or most likely wedge it self somewhere,Its about 3/4 " long and about 3/16 wide. Thanks..Frank
You could do an oil change. That may help flush it down into the sump. If it finds it's way to the sump I am guessing you will be ok.
