Old 02-04-2020, 10:22 AM   #1
jpc763's Avatar
2001 S coolant leak questions
My 2001 S pumped out about a quarter cup of coolant last drive. This was on the garage floor after the drive.
I have had both the waterpump and the overflow reservoir replaced in the past 3 years as well as installing the blue cap about 5 years ago.
TIA, John
2001 Boxster S - Midnight Blue Metalic
jpc763 is offline   Reply With Quote
Old 02-04-2020, 10:25 AM   #2
jpc763's Avatar
View from in front of passenger rear wheel
View from through passenger rear wheel
Old 02-04-2020, 12:59 PM   #3
911monty's Avatar
In the second picture I see a wet bolt. I'd check the plastic hose connector from the oil/water exchanger to the expansion tank. It is almost directly above that area. They have failed before.
Old 02-04-2020, 01:22 PM   #4
Who's askin'?
maytag's Avatar
I agree with 911monty. The good news here is that it's not wet EVERYWHERE, which is frequently the case with a leak on the bottom.
Take your flashlight and follow the trail up. I think you're likely to find a slipped hose clamp, or some such.
Otherwise: what brand expansion tank did you use when you replaced it?
Old 02-04-2020, 02:52 PM   #5
Hmm ..URO?
Sorry could not help it..
Old 02-04-2020, 07:12 PM   #6
Racer Boy
Racer Boy's Avatar
I had a coolant tank cap fail after only three years, so it's possible that could be your culprit.
Old 02-04-2020, 08:41 PM   #7
FWIW....If you do have to replace the tank, don’t think you will be saving your knuckles or money buying anything other than a Porsche tank. As I see quoted on here and always get a laugh, “Ask me how I know” Hopefully you won’t need to replace the tank.
robdelorenzo is offline   Reply With Quote
Old 02-05-2020, 08:19 AM   #8
jpc763's Avatar
Thanks for all the input. I am not going to be able to get it up in the air until the weekend. I will check then.
Old 02-05-2020, 12:20 PM   #9
911monty's Avatar
Why the difficulty?
1.Put the top in the service mode
2. Remove storage cubby and top engine cover.
3. Look at top of engine for leak
4. In as little as 10 minutes. Perhaps save expensive engine damage.
Old 02-05-2020, 12:29 PM   #10
jpc763's Avatar
Why the difficulty?
I was under the impression that I needed to get underneath the car. For that I have to jack it up and put it on stands.
I can totally do the above procedure.
For reference, since I noticed the fluid, I have not started the car.
Old 03-04-2020, 01:58 PM   #11
jpc763's Avatar
New overflow tank required. Just got it back from my indy mechanic.
Old 03-04-2020, 03:21 PM   #12
1998 Boxster Silver/Red
Great! Questions...
OEM Part? How much $$?
How much was the labor$$
In a nutshell... how much $$ out the door?
1998 Porsche Boxster
Old 03-04-2020, 08:44 PM   #13
jpc763's Avatar
Great! Questions...
Tank was OEM and was $450
Labor was $700
Tax and other environmental charge and total was $1200
This is the 2nd one I have had put in. First one failed 6 years ago.
Old 03-05-2020, 04:49 AM   #14
Labor was $700
That's one project I haven't yet done... though my tank looks fairly new (bought the car in 8.17). That's going to be one project I'll be tackling.
Glad to hear you've got everything in order!
